OData for Jira
Get a RESTful OData API server for your Jira data and make it available to clients in just a few minutes with Skyvia!
Expose Jira Data via OData
While Jira provides its own web API for data access, using a widely accepted OData standard for data access over the Internet is preferred in many cases. OData is supported in a number of data-related applications and technologies, and it makes consume your real-time Jira data or integrate them with other applications much easier.
Make your Jira data readily available in BI tools, web and mobile applications, integration interfaces, etc. with Skyvia Connect. Get OData API layer with no coding, in just a few minutes!
If you need to provide access to your Jira data to your colleagues, clients, or other people, Skyvia Connect can offer several advantages.
Skyvia Connect provides bi-directional access to live Jira data in real time.
Create users and define passwords in the endpoint itself — no need to give your Jira credentials. Limit access by IP if needed.
Expose only the Jira tables and columns you need to share. Other tables and columns remain unavailable via the endpoint.
Create a connection to your Jira.
Share Jira data easily
