OData REST API for Azure SQL Data Warehouse
Restify Your Azure SQL Data Warehouse Data via the Cloud
Need to expose Azure SQL Data Warehouse database via REST API? Let Skyvia do it for you! Our cloud service allows you to almost instantly restify your Azure SQL Data Warehouse database with no coding and very little configuration required.
  • Web API server for Azure SQL Data Warehouse data in minutes with no coding
  • No need to care about hosting and maintenance.
  • Connect your database to web and mobile applications, BI tools, Salesforce Connect, etc.
OData — More Than Just REST
Skyvia allows you to easily expose your Azure SQL Data Warehouse data via OData — RESTful API for data access and manipulation. OData is a widely accepted open standard for data access over the Internet. It can be used for exposing any kind of data and is supported in a number of data-related applications and technologies.
OData Support by Skyvia Connect
  • Support for all OData versions
  • Writable OData endpoints
  • Support for ATOM and JSON format for returned data
OData Query Features Support
  • Feature
  • Number of records
  • Querying specific fields
  • Querying first records
  • Paging
  • Ordering data
  • Querying joined tables
  • Filtering data
  • Aggregating data
  • OData Keyword
  • $count
  • $select
  • $top
  • $top + $skip
  • $orderby
  • $expand
  • $filter
  • $apply=aggregate
No Coding Required
Create a RESTful OData service for your Azure SQL Data Warehouse database in minutes without a line of code! Expose your tables via drag-n-drop, include or exclude fields visually, and Skyvia Connect will take the rest.
Built-in Security Layer
You don’t need to give credentials to the exposed Azure SQL Data Warehouse database. Instead define user names and passwords to your OData endpoint on the Skyvia side. If this is not enough, you can also limit access to the allowed IPs and IP ranges.
Skyvia logs all connections to your Connect OData services with user accounts and IP addresses, all their requests and queries. Whenever necessary you can monitor which users access your data and what they do with them.
Create a connection to your Azure SQL Data Warehouse.
Share Azure SQL Data Warehouse data easily
