Zoho Inventory R Integration
Zoho Inventory connector for Integration with R. Easily load Zoho Inventory data to a database and analyze it with R.
Analyze Your Zoho Inventory with R
The best way to perform an in-depth analysis of Zoho Inventory data with R is to load Zoho Inventory data to a database or cloud data warehouse, and then connect R to this database and analyze data. Skyvia can easily load Zoho Inventory data (including Invoices, Bills, Items, Orders, etc.) to a database or a cloud data warehouse of your choice.
SourceSkyviaData WarehouseBI Tool
Integrate Zoho Inventory to Database or Data Warehouse
Use ELT or ETL Integration Process
ELT (Replication)
ELT process supposes simple copying cloud data to a data warehouse or a database as-is, leaving all the transformation tasks for the database server. This is often uses, for example, when loading data to cloud data warehouses with affordable and nearly unlimited computing power for transformations. In Skyvia, this task is solved with easy-to-configure Replication packages.
ETL (Import)
ETL process supposes that data structure in source and target is different, and data must be transformed before loading it into target database. For example, you may want to create a schema for OLAP or simply have target tables for data already created. In Skyvia, this is task solved with Import packages, having powerful mapping and transformation capabilities.
Zoho Inventory Replication Features
Simple No-coding Setup
All you need to do is to specify parameters for connecting to Zoho Inventory and data warehouse and select which data to replicate.
Keep Data Up-to-Date
Skyvia’s Replication Tool will painlessly ensure you always have the most current data from your cloud applications in your data warehouse.
Automatic Schema Creation
You don’t need to prepare the database — Skyvia creates the tables, corresponding to the source objects, in the data warehouse automatically.
Zoho Inventory Import Features
Powerful Data Transformations
Import of New and Updated Data
Preserve Data Relations
With Skyvia all the relations between the imported Zoho Inventory objects will be preserved. You need just to specify them in mapping.
Connect Zoho Inventory and R with minimal effort and in only a few clicks!
