The best way to perform an in-depth analysis of Help Scout data with Jupyter is to load Help Scout data to a database or cloud data warehouse, and then connect Jupyter to this database and analyze data. Skyvia can easily load Help Scout data (including Customers, Users, Webhooks, etc.) to a database or a cloud data warehouse of your choice.
Connect Help Scout and Jupyter with minimal effort and in only a few clicks!
