The best way to perform an in-depth analysis of Motion data with RapidMiner is to load Motion data to a database or cloud data warehouse, and then connect RapidMiner to this database and analyze data. Skyvia can easily load Motion data (including Tasks, RecurringTasks, Comments, Projects etc.) to a database or a cloud data warehouse of your choice.
All you need to do is to specify parameters for connecting to Motion and data warehouse and select which data to replicate.
With Skyvia all the relations between the imported Motion objects will be preserved. You need just to specify them in mapping.
Connect Motion and RapidMiner with minimal effort and in only a few clicks!
