Automatic Schema Creation
You don’t need to prepare the Azure Synapse Analytics database — Skyvia creates the tables, corresponding to the Front objects, in the data warehouse automatically.
Many businesses want to benefit from the Azure Synapse Analytics ability to quickly perform complex analytical queries over petabytes of data, and need to load their data from Front and other applications to the Azure Synapse Analytics service for centralized storing and data analysis. Skyvia is the perfect tool for secure replication to a data warehouse, as it loads data much faster than standard ETL tools and allows you to configure the replication in a few simple steps:
Create Front and Azure Synapse Analytics connections.
Select Front objects to copy to Azure Synapse Analytics.
Optionally specify schedule to update data in Azure Synapse Analytics with recent data from Front automatically.
With Skyvia you can extract and load all the data from a Front object or disable loading for some Front object fields. You can also configure filters for data to replicate.
Skyvia not just copies Front data to Azure Synapse Analytics once, it can keep your Azure Synapse Analytics database up-to-date with Front automatically, ensuring you always have fresh data for data analysis without any user intervention.
Skyvia combines a high-performance optimized batch data loading into Azure Synapse Analytics with a granular, per-record data insertion and error logging in case of any errors.
You can find detailed logs for each execution in the package Run History.
Integrate Front and Azure Synapse Analytics with minimal effort and in only a few clicks!
