Automatic Schema Creation
You don’t need to prepare the MariaDB database — Skyvia creates the tables, corresponding to the Help Scout objects, in the data warehouse automatically.
Copying Help Scout data to MariaDB cannot be simpler. You just need to perform the following three simple steps.
Specify necessary connection parameters for Help Scout.
Specify necessary connection parameters for MariaDB.
Select Help Scout objects to replicate.
With Skyvia you can extract and load all the data from a Help Scout object or disable loading for some Help Scout object fields. You can also configure filters for data to replicate.
Skyvia not just copies Help Scout data to MariaDB once, it can keep your MariaDB database up-to-date with Help Scout automatically, ensuring you always have fresh data for data analysis without any user intervention.
Skyvia combines a high-performance optimized batch data loading into MariaDB with a granular, per-record data insertion and error logging in case of any errors.
If you need more than just to copy data from Help Scout to MariaDB, you may use Skyvia’s powerful ETL functionality for Help Scout and MariaDB integration. Skyvia’s data import tools will correctly extract Help Scout data, transform it, and load to MariaDB when MariaDB tables have different structure than Help Scout objects. Moreover, Skyvia Data Import allows loading data in any direction, supporting Reverse ETL scenario.
You can find detailed logs for each execution in the package Run History.
Integrate Help Scout and MariaDB with minimal effort and in only a few clicks!
