Automatic Schema Creation
You don’t need to prepare the Snowflake database — Skyvia creates the tables, corresponding to the Help Scout objects, in the data warehouse automatically.
Many businesses want to benefit from the Snowflake ability to quickly perform complex analytical queries over petabytes of data, and need to load their data from Help Scout and other applications to the Snowflake service for centralized storing and data analysis. Skyvia is the perfect tool for secure replication to a data warehouse, as it loads data much faster than standard ETL tools and allows you to configure the replication in a few simple steps:
Create Help Scout and Snowflake connections.
Select Help Scout objects to copy to Snowflake.
Optionally specify schedule to update data in Snowflake with recent data from Help Scout automatically.
With Skyvia you can extract and load all the data from a Help Scout object or disable loading for some Help Scout object fields. You can also configure filters for data to replicate.
Skyvia not just copies Help Scout data to Snowflake once, it can keep your Snowflake database up-to-date with Help Scout automatically, ensuring you always have fresh data for data analysis without any user intervention.
Skyvia combines a high-performance optimized batch data loading into Snowflake with a granular, per-record data insertion and error logging in case of any errors.
You can find detailed logs for each execution in the package Run History.
Integrate Help Scout and Snowflake with minimal effort and in only a few clicks!
