Automatic Schema Creation
You don’t need to prepare the Azure Synapse Analytics database — Skyvia creates the tables, corresponding to the Motion objects, in the data warehouse automatically.
Many businesses want to benefit from the Azure Synapse Analytics ability to quickly perform complex analytical queries over petabytes of data, and need to load their data from Motion and other applications to the Azure Synapse Analytics service for centralized storing and data analysis. Skyvia is the perfect tool for secure replication to a data warehouse, as it loads data much faster than standard ETL tools and allows you to configure the replication in a few simple steps:
Create Motion and Azure Synapse Analytics connections.
Select Motion objects to copy to Azure Synapse Analytics.
Optionally specify schedule to update data in Azure Synapse Analytics with recent data from Motion automatically.
With Skyvia you can extract and load all the data from a Motion object or disable loading for some Motion object fields. You can also configure filters for data to replicate.
Skyvia combines a high-performance optimized batch data loading into Azure Synapse Analytics with a granular, per-record data insertion and error logging in case of any errors.
You can find detailed logs for each execution in the package Run History.
Integrate Motion and Azure Synapse Analytics with minimal effort and in only a few clicks!
