Automatic Schema Creation
You don’t need to prepare the SQL Azure database — Skyvia creates the tables, corresponding to the Unbounce objects, in the data warehouse automatically.
Copying Unbounce data to SQL Azure cannot be simpler. You just need to perform the following three simple steps.
Specify necessary connection parameters for Unbounce.
Specify necessary connection parameters for SQL Azure.
Select Unbounce objects to replicate.
With Skyvia you can extract and load all the data from a Unbounce object or disable loading for some Unbounce object fields. You can also configure filters for data to replicate.
Skyvia combines a high-performance optimized batch data loading into SQL Azure with a granular, per-record data insertion and error logging in case of any errors.
If you need more than just to copy data from Unbounce to SQL Azure, you may use Skyvia’s powerful ETL functionality for Unbounce and SQL Azure integration. Skyvia’s data import tools will correctly extract Unbounce data, transform it, and load to SQL Azure when SQL Azure tables have different structure than Unbounce objects. Moreover, Skyvia Data Import allows loading data in any direction, supporting Reverse ETL scenario.
You can find detailed logs for each execution in the package Run History.
Integrate Unbounce and SQL Azure with minimal effort and in only a few clicks!
