10 Top FiveTran Alternatives & Competitors in 2026 [Free & Paid]
Data is a goldmine, and it’s best to have it on demand on whichever system you need. You might have heard of the Fivetran tool that helps to load data into a data warehouse using its pre-built connectors. It provides seamless integration with programs, databases, files, and events. The ready-to-use connectors save time and effort by creating an automated data flow on your schedule. The demand for better business intelligence and analytics is driving the growth of these tools.
The market size for business intelligence and analytics software applications is forecast to increase worldwide over the next few years, from 15.2 billion U.S. dollars in 2020 to more than 18 billion in 2025
But did you know there are plenty of alternative Fivetran competitors that can suit your business purpose or even perform better and deliver more value at an economical cost? In this article, you can learn about the top Fivetran competitors and narrow down choices that could best meet your requirements.
Before we dive into the comparative analysis details, here’s a relative chart that gives you a snapshot view of Fivetran alternatives. This value-added chart will help you get an overall idea of offerings from companies like Fivetran. Here’s the comparison list of the ten ELT and ETL tools.
CategoriesStageTarget segmentDeploymentBusiness modelPricingLocation
SkyviaELT toolLate stageEnterprise, Mid-sizeSaasCommercialFreemiumPrague, Czech Republic
Hevo dataELT toolLate stageEnterprise, Mid-sizeSaasCommercialFreemiumCalifornia, U.S.
StitchELT toolMid-stageEnterprise, Mid-sizeSaasOpen coreContact salesPhiladelphia Us
MatillionELT toolLate stageEnterprise, Mid-sizeSaasCommercialFreemiumManchester, U.K.
AirbyteELT toolEarly-stageEnterprise, Mid-sizeSaasOpen SourceContact salesSan Francisco, US
Integrate.ioData Warehousing, ETL and reverse ETL, ELTMid-stageEnterprise, Mid-sizeSaasCommercialFree Trial, Contact salesCalifornia, U.S.
TalendELT Tools, Data Privacy and GovernanceLate stageEnterprise, Mid-sizeSaasCommercialFree TrialCalifornia, U.S.
InformaticaData Cataloging, ETL ToolsLate stageEnterprise, Mid-sizeSaasCommercialFree TrialCalifornia, U.S.
AWS GlueETL toolMid-stageEnterprise, Mid-sizeSaasCommercialContact salesUS
RiveryData Modelling and Transformation, ELT Tools, Workflow OrchestrationMid-stageEnterprise, Mid-sizeSaasCommercialFree Trial, Contact salesNew York, US
Now that you have some idea of the list of tools, let’s look at the Fivetran alternatives with their pros and cons and get an idea of their pricing.
  1. Skyvia
  2. Hevo Data
  3. Stitch
  4. Matillion
  5. Airbyte
  6. Integrate.io
  7. Talend
  8. Informatica
  9. AWS Glue
  10. Rivery
Skyvia is a robust cloud-based data platform offering businesses and organizations a simple yet comprehensive solution for data integration, backup, querying, and data connectivity. It simplifies and accelerates retrieving information, maintaining cloud-based data, and accessing diverse data sources.
Users of Skyvia can use it without coding, too, as a simple wizard guides them through the procedure. This functionality makes it simple to work with cloud-based data. Know more about Skyvia.
  • Skyvia has scheduled bidirectional data integration to/from multiple sources.
  • Automatic mapping saves a lot of time.
  • All connectors are included in the price.
  • The synchronization process could be a little bit faster.
  • Email notification isn’t available when integration is ready.
Skyvia has a FREE plan for Data integration, Backup, Query, and connect, and it also has plans ranging from 79$ per month to 399$ per month based on records and scheduling. You can get offers of 20% off on all monthly subscriptions.
Hevo Data
Hevo is a codeless, fully-automated data pipeline solution that expedites and simplifies data transfer from all sources to your warehouse. Hevo enables the reliable and real-time loading of data from any source, including relational databases, SaaS apps, S3 buckets, files, and NoSQL, to any of your warehouses, such as Snowflake, Google BigQuery, and Amazon Redshift. Moreover, Hevo supports 100+ pre-built connectors spanning SDKs, cloud storage, streaming services, databases, and SaaS applications.
  • With only a few clicks, configuration and setup are made simple.
  • Possibility to set up ETL without coding skills.
  • Excellent customer service team with friendly individuals.
  • Integration of data without hiccups.
  • Excellent user interface.
  • Not being able to schedule a pipeline job for a specific time of the day.
  • Confusing transformations.
  • High CPU usage.
  • Tricky in the beginning.
One of the three pricing plans offered by Hevo Data is free. This plan permits the use of unlimited data sources and models. You receive email support, a single sign-on, and a total number of user seats. With the free plan, consumers can experience up to one million events.
The business plan’s price is negotiable and established in conjunction with the client by the Hevo team.
Stitch
Stitch Data is an open-source tool for integrating data from multiple systems (a warehouse) into a single platform. It is an ETL (extract, transform, and load) tool that transfers data from various systems to one and simplifies the reporting process. Like other solutions on the market, it extracts data from many channels and campaigns and compiles it into a centralized dashboard.
  • Accurate sales and product reports.
  • Easy-to-generate reports.
  • Effective for saving time.
  • Fast integration.
  • Great interface.
  • Friendly GUI.
  • It’s challenging to traverse the inventory list.
  • Learning can be time-consuming.
  • The absence of a designated dashboard sometimes causes customer support delays.
Standard: This is the primary plan. Here, you have access to a single data warehouse and can only receive support via chat. The price ranges from $100 to $1,250 based on the number of millions of rows required.
Stitch Unlimited: With a bespoke fee that exceeds $1,250 per month, Stitch Unlimited offers five data warehouses and platinum customer support.
Stitch Unlimited Plus: With infinite integrations, more rights, and impeccable customer service.
Matillion
Matillion Data Loader simplifies data migration into a cloud-based data warehouse of your choosing, such as Amazon Redshift, Google BigQuery, or Snowflake. The free SaaS-based data integration tool offers immediate access to your data, enabling you to innovate more rapidly and make more intelligent timely business decisions. Support your migration efforts by integrating with numerous popular data sources at no extra charge.
  • Matillion’s robust GUI-based data transformation capabilities give businesses a straightforward method for organizing queries and their linkages for data modeling.
  • Another distinctive feature of the Matillion platform is the possibility of deploying the product on-premises.
  • Since data loading capabilities and transformation are both available on the Matillion platform, it may be easier to apply data governance best practices than with an independent replication and transformation strategy.
  • Matillion has a smaller selection of connectors than other leading ETL systems.
  • The user experience centers around its GUI-based morphing features.
  • Because Matillion is capable of more than data replication, it may have fewer partnerships for other capability sets than competing ETL solutions.
Matillion offers a free plan. Pricing is provided via Credits, beginning at $2.00 per credit. Matillion Credits can pay for Virtual Core hours when executing Matillion instances. One Matillion Credits corresponds to one Virtual Core hour. There are also annual rates available.
Airbyte is an open-source data integration solution with pre-built API and U.I. connectors. More than 800 businesses use the platform to synchronize their data in real-time. In addition, companies can self-host Airbyte, eliminating the possibility of third-party involvement. Engineers can choose raw data to begin their normalization processes by utilizing services like optional normalized schema.
  • Airbyte provides an open-source data integration platform. In contrast to many ELT manufacturers, clients can use Airbyte Cloud (a SaaS service) or deploy an open-source version of Airbyte on their own.
  • It provides a CDK as an alternative to creating code from scratch to expedite development.
  • They support over twenty locations. When you require data put into a custom-built platform.
  • For long-tail integrations built using the Airbyte CDK, your team is responsible for maintenance, support, and resolving anything that breaks.
  • Many of Airbyte’s connectors are either in development or need to be ready for production.
  • The price structure of Airbyte is not apparent. With a credit-based, volume-based consumption approach, it might be challenging to estimate usage and reduce expenses as data quantities increase.
Airbyte offers a volume-based model with three pricing plans, one of which is free. The enterprise version provides custom costs and advanced features such as priority support, onboarding assistance, etc.
Integrate.io
Integrate.io is an E-commerce-Specific Data Warehouse Integration Platform. The Integrate.io Platform provides affordable access to ETL & Reverse ETL, ELT & CDC, API Management, Data Warehouse Monitoring, and Data Observability.
  • Simple to use the tool.
  • Incredibly customizable.
  • Drag-and-drop UI for easy use.
  • Easy third-party platform integration.
  • Excellent customer service team.
  • It may lack ease of use for some users.
  • Debugging can be challenging when error logs lack specificity.
  • Interaction between fields or packages is slow.
Integrate.io doesn’t provide any free plan, but it provides a Free trial. The subscription model of integrate.io for no code data pipeline platform is based on the number of node hours ranging from monthly 1,199$ to 5,999$
Talend
Talend is a data management application built on Java code with a workflow user interface. Talend delivers a package of enterprise data management tools. While Talend supports more than a thousand non-native connectors, its fully-coded, open-source architecture has a steep learning curve for customers unfamiliar with its interface. Talend’s per-seat pricing model is essential for increasing data teams seeking to scale.
  • Robust data orchestration capabilities.
  • Some AI/ML capabilities allow data scientists to model data.
  • Data governance.
  • Big data streaming.
  • The capacity to consider sources as destinations.
  • Desktop design reliance.
  • Infrastructure costs.
  • Complex workflow design and configuration.
  • Unnatural connectors.
Talend Cloud costs $12k per user per year or $1170 per user per year for unlimited usage. Talend Data Fabric provides custom pricing that is often more expensive than Talend Cloud.
Informatica
Informatica Big Data is database management software that helps enterprises capture and process large amounts of data in real-time. Informatica Big Data is a cloud-ready platform. This enables users to manage data assets from any location, at any time, and on any device, without the limits of on-premise Hadoop distributions.
  • Effective GUI interfaces for Session monitoring, Job Scheduling, ETL Design, Debugging, Administration, etc.
  • Queued Message.
  • Third-party application data.
  • Mainframe and file-based data.
  • XML and unstructured data.
  • Accessibility to a wide variety of data sources of the company.
  • Load stabilization and parallel processing.
  • In the repository manager, moving an object from one folder to another is impossible.
  • Further, you cannot import XML export files.
  • Also, it includes Mappings, and one can do workflow development too.
Informatica’s several products can contain several optional components. Integration Cloud’s base edition begins at $2,000 per month. The unknown is the cost of add-on tiers. Informatica offers 30-day free trials on the majority of its products.
AWS Glue
AWS Glue is a managed extract, transform, and load (ETL) service that simplifies data preparation and loading for analytics. This tool allows users to create and execute ETL jobs in the AWS Management Console. AWS Glue identifies data and stores the related metadata (e.g., table definition and schema) in the AWS Glue Data Catalog when users direct it to AWS-hosted data. After being cataloged, data is immediately searchable and queryable.
  • It is swift, easy, and self-intuitive.
  • As it is a managed service, one can take care of only a few underlying details.
  • It is a pay-as-you-go service. So, there is no need to provide any capacity in advance.
  • AWS Glue runs on Apache Spark. So, to make the best of the AWS Glue service, the developer should have a good idea of Apache Spark.
  • AWS Glue crawlers sometimes mismatch the data in the files.
  • Sample Code is very basic and only available in some scenarios.
AWS Glue follows a pay-as-you-go pricing model, which charges $0.44 per DPU-Hour for each Apache Spark or Spark Streaming job, billed per second with a 1-minute minimum (Glue version 2.0 and later) or 10-minute minimum (Glue version 0.9/1.0).
Rivery
Rivery is a cloud-based service that provides business intelligence tools to manage and automate data pipelines for small to large companies. It has a single dashboard that lets users get insight into corporate operations, evaluate organizational performance, and generate activity reports utilizing key performance indicators (KPI).
  • The learning curve while using Rivery is incredibly flat.
  • Rivery’s support is incredibly professional, responsive, and efficient.
  • It manages incremental extraction from systems like Salesforce or NetSuite.
  • While creating complex scripts might be frustrating to rearrange the various building blocks using drag and drop.
  • Lack of different “roles” for users.
Rivery offers both pay-as-you-go pricing on demand and annual contracts. All plans include both pay-as-you-go and annual price options. The credit-based pricing structure begins at $0.75 per credit. The cost of database sources comes from the total amount of data sent.
If you want to have a detailed view of Fivetran and other data integration tools, we have you covered! Compare features, benefits, data sources and destinations, and pricing plans to choose the best ETL tool for your business case.
Knowing about various alternatives to Fivetran and their benefits helps to create awareness which is critical to making your buying decision. We recommend that you can shortlist a few and then make an in-depth comparison against your requirements to help make an informed choice.
Skyvia is a cloud-based data integration, backup, and management platform for businesses of all sizes, so we’d encourage you to try Skyvia.
Babu Tharikh
Babu Tharikh
Salesforce Technical Writer
Skyvia Free Trial 2026
