How to Store Data for Power BI: Best Options
Reports that crawl, or a refresh that dies with a size error? Often the trouble started earlier, with where the data was put before Power BI ever saw it. And no, there isn't one right answer. What decides the best way to store data for Power BI for you is how much data there is, how fresh it has to be, and who's going to babysit the storage.
Under the hood Power BI does one of two things: it copies the rows in, or it leaves them alone and sends queries when a report needs data. Small teams often get far with Excel files on SharePoint and Import mode. That setup tends to hold until a model creeps toward the size cap, or a sales lead wants today's numbers by lunch, and that's when we'd move the data into Azure SQL, Synapse or Fabric.
We'll begin with the five connection modes, because each one keeps your rows in a different physical place. After that come files, on-premises SQL Server, cloud databases, dataflows and Fabric side by side, plus a short set of questions to run your own reports through.
Understanding Power BI’s Data Connection Modes
The storage options themselves are the reason we are all gathered here today. Yet, before we feast on them, we need to discuss how Power BI connects to data – an important part of any BI strategy. Here are the five main connection modes:
ModeStorage & Real-Time Data Modeling Flexibility & Performance Sources Support Best For
ImportStored in Power BI, not real-time High flexibility, moderate performance Most sources Small/medium, complex modeling
DirectQueryReal-time, no local storage Moderate flexibility, performance depends on the source Many databases, some cloud sources Large/real-time, security needs
Live Connection No storage in Power BI, real-time Limited flexibility, high performance SSAS, Azure AS, Power BI Datasets Centralized enterprise models
Direct LakeNot stored in Power BI, real-time syncing High flexibility, optimized performance Azure Data Lake (Fabric) Big data, lakehouse analytics
Composite (Dual)Combination of storage and real-time High flexibility, excellent performance Mixed Hybrid, flexible scenarios
Import Mode
It’s Power BI’s bread and butter. It pulls all data into its highly-compressed in-memory engine called VertiPaq. Once it’s there, everything runs like a dream.
Best for: Compact to mid-sized datasets where analytical depth matters more than live streaming, requiring sophisticated modeling horsepower.
Power BI Import Mode pros and cons
DirectQuery Mode
It summons Power BI to the data source every time someone starts a query.
Best for: Large or highly dynamic datasets where staleness is the natural enemy, or when security protocols forbid duplication.
Power BI DirectQuery Mode pros and cons
Live Connection Mode
It bypasses the raw data quarry entirely, instead letting Power BI plug straight into a ready-made interpretive layer within Power BI Service, Azure Analysis Services, or SQL Server Analysis Services (Tabular or Multidimensional).
Best for: Enterprise environments with established semantic models and strict governance requirements.
Power BI Live Connection Mode pros and cons
Direct Lake Mode
It’s designed specifically for Microsoft Fabric environments and promises breakneck-speed access to massive datasets in Azure Data Lake without importing or translating queries.
Best for: Organizations using Microsoft Fabric for big data analytics that need high-speed access to massive datasets.
Power BI Direct Lake Mode pros and cons
Composite Mode or Dual Mode
The name speaks for itself: it allows you to mix and match different connection modes within one Power BI model.
Best for: When you’re working with historical (for trend analysis) and real-time data (for current operations), or when you want to reduce storage costs.
Power BI Composite or Dual Mode pros and cons
Where Does Power BI Store Your Data?
Import mode is the case where Power BI holds a copy of your rows itself (Dual tables too, since they can act as Import tables). With DirectQuery or a live connection, nothing gets copied over: the rows stay put in the source, and what Power BI saves is the model definition and some cached visual results. Direct Lake is a bit of a hybrid, because the data lives in OneLake but columns get pulled into memory once a report asks for them.
ModeWhere the rows liveWhat Power BI keeps
Import in Power BI DesktopInside your .pbix fileA compressed in-memory copy, updated on refresh
Import, published to the serviceMicrosoft-managed Azure storage in your tenant's home regionThe semantic model with the imported data
DirectQueryYour source databaseSchema and metadata, plus visual and dashboard tile caches
Live connectionAn Analysis Services model or a published semantic modelThe report; the upstream model holds the data
Direct LakeDelta tables in OneLake (Microsoft Fabric)Metadata; columns load into memory on demand
In the Power BI service, artifact data goes to Azure Storage and metadata to Azure SQL databases. Both are encrypted by default with Microsoft-managed keys. To see the region, sign in, open the Help pane, select About and look for "Your data is stored in".
Size is the other half of the answer. By default, the service caps an imported semantic model at 1 GB. Fabric capacities raise that ceiling if you switch on the large semantic model storage format, and then the model can grow as big as the capacity allows (or as big as your admin lets it). One catch, though: publishing from Power BI Desktop still tops out at 10 GB per upload.
Can Power BI act as your database? Not well. Imported tables only know what the source said at the last refresh. And incremental refresh throws away partitions once they slide past the archive window you set. So if anyone will ask about last year's prices, or a deal somebody deleted in March, that history belongs in a database or a warehouse. Skyvia replication covers this case: it loads cloud app data into the warehouse on a schedule, and history mode keeps each version of a record instead of overwriting it.
Common Data Storage Options for Power BI
Finally, let’s discuss where your records reside. The storage landscape for Power BI is quite versatile, and everyone will find their cup of tea.
The beauty of Power BI lies in its source flexibility. But not all storage options are created equal, and your choice will ripple through everything from refresh schedules to user experience.
File-Based Storage (Excel, CSV, SharePoint)
This is where most analysts cut their teeth. Files are familiar, easy to understand, and perfect for getting your feet wet in the Power BI pool.
Excel files are old and reliable, sitting on virtually every business computer, and most people know how to work with them. CSV files are the universal donor of data formats – lightweight, fast to process, and compatible with practically everything. SharePoint takes these familiar formats and adds collaboration superpowers, letting teams work together without frequent follow-ups.
Best for: Small datasets, beginners who want to spring from zero to hero, and quick analyses that don’t require enterprise-level infrastructure.
File-based storage for Power BI pros and cons
File-based storage may seem a bit outdated compared to all the other options, yet it’s the alpha and omega of business information preservation. There is also a solution that makes these cons less likely to affect your operations, and those pros more impactful.
With tools like Skyvia, you can automate the ETL pipeline building. For example, it pulls records from your CRM, marketing platforms, and databases, then feeds them into SharePoint or OneDrive, where Power BI can access them.
On-Premises Databases (SQL Server)
They are the backbone of many enterprise BI architectures. SQL Server is Microsoft’s flagship database that integrates with Power BI like peanut butter with jelly. It supports all connection modes, handles complex queries, and scales from small databases to enterprise data warehouses (DWH).
Best for: When organizations with existing on-premises infrastructure need more control over their data. If you’ve already got SQL Server boxes humming in your datacenter and a team that knows how to keep them happy, this path makes perfect sense.
On-premises databases for Power BI pros and cons
Cloud Databases (Azure SQL Database, Azure Synapse Analytics)
They represent the modern storage philosophy – scalable, elastic, and seamlessly woven into analytical ecosystems. Azure SQL Database offers the beloved SQL Server experience with cloud scalability, automatic backups, and native intelligence. Azure Synapse Analytics can handle petabytes of data and supports both SQL and Spark workloads.
Best for: When you need to handle large and growing datasets, or build for the future, and want to access the newest analytics capabilities.
Cloud-based databases for Power BI pros and cons
Also, storage mode and storage type correlate. So, you will need to align both of them:
Storage Mode File-Based Storage On-Premises Databases Cloud Databases Key Characteristic
Import  Supported (files imported fully into the PBIX model) Supported (data imported fully) Supported (data imported fully) Fastest query performance, supports full modeling, data refresh needed, size limits apply
DirectQuery Limited support (mostly via cloud file formats like Parquet in Data Lake) Supported (SQL Server, SSAS, etc.) Supported (Azure SQL DB, Synapse, Fabric Lakehouse) Real-time data access, limited modeling, performance depends on source, no duplication
Live Connection Not applicable Supported (SSAS models on-premises) Supported (Azure Analysis Services, Power BI datasets) No local storage, real-time queries, no local modeling in Power BI Desktop, centralized governance
Direct Lake Supported (Parquet files in Fabric Lakehouse) Not typical Supported (Fabric Lakehouse, Azure Data Lake) Near real-time analytics on large datasets, no data movement, requires a Microsoft Fabric environment
Composite (Dual) Supported for dimension/reference tables from files Supported Supported Combines the benefits of Import and DirectQuery, useful for composite models with mixed data freshness needs
Advanced Data Storage Solutions in Power BI
If basic file and database storage are the foundation of a Power BI building, then Dataflows, Datamarts, and Data Fabric Warehouses are the smart home automation that makes everything work together. These advanced storage solutions are Microsoft’s answer to the age-old BI challenge: how do you create reusable, scalable, and governed data assets without turning your analysts into full-time data engineers?
Power BI Datamarts have been retired in favor of Fabric Data Warehouse, so reports built on a datamart need a new source. Below, we discuss the new player and how Skyvia can help you move the data there, or to a warehouse outside Microsoft.
Power BI Dataflows
Think of them as a cloud, self-service ETL tool powered by the same Power Query engine that drives your beloved Power BI Desktop. But here’s the plot twist – instead of your transformation masterpiece being trapped in report silos, Dataflows set it free to roam across your entire Power BI ecosystem and other Microsoft services.
Best for: If you’ve ever found yourself thinking, “I wish I could just copy this cleaned customer table to five other reports without starting from scratch,” Dataflows are your new best friend. Also, it will help with centralizing and standardizing ETL logic for enterprise data.
Power BI Dataflows pros and cons
Power BI Datamarts VS Power BI Data Fabric Warehouse
If Dataflows are transformation factories, then Datamarts were complete DWH solutions in a box. They combined a dataflow (for ETL), an Azure SQL Database (for relational storage), and a dataset (for semantic modeling), all wrapped up in one neat package. Microsoft has since retired them.
Teams that used them now keep that data in Fabric Data Warehouse or move it to a third-party warehouse.
Power BI Data Fabric Warehouse is Microsoft’s modern cloud-native DWH that’s fully integrated into the broader Microsoft Fabric platform. It’s designed to unify, store, process, and analyze massive volumes of both structured and semi-structured data, all while using Delta Lake storage format on Azure Data Lake Gen2 (known as OneLake in Fabric).
Best For:
  • Enterprise-scale analytics, when you need to consolidate row-level data from different sources and run large-scale analytical queries without breaking a sweat.
  • It’s also a godsend for migration from legacy warehouses.
  • For organizations wanting unified analytics and AI.
  • Translytical scenarios, when both transactional and analytical processing must occur within the same system for real-time analytics needs.
  • Finally, if compliance and governance keep you up at night, Fabric Data Warehouse comes with Microsoft-grade security and auditing baked right in.
Power BI Data Fabric Warehouse pros and cons
How to Safeguard Data When Saying Goodbye to Datamarts
While Microsoft is rolling out the red carpet for their new Data Fabric Warehouse, sometimes the grass is greener on the other side – and that’s where third-party DWHs like Snowflake, Google BigQuery, and Amazon Redshift come into play. This option makes sense when:
  • You’re afraid that Microsoft may decide to change something in the BI infrastructure again.
  • Need to extensively transform data while moving.
  • Want to work with a source that supports CDC.
  • Business users will be responsible for the transfer.
  • There’s no time to train your team on Fabric, and the reports have to work again soon.
  • Want to keep options open – move to the different targets within one tool, instead of using multiple Power BI connectors.
  • Your data exceeds Power BI’s Import mode limits (1 GB compressed for Pro, up to 100 GB+ for Premium/Fabric).
Skyvia, in this scenario, is your friendly neighborhood data moving service – but instead of hauling furniture, it’s hauling business intelligence. This no-code platform takes the headache of data migration, making it accessible whether you’re a SQL wizard or someone who thinks ETL is a type of sandwich.
Skyvia Automation components pane
Let’s see how this can be organized using a hypothetical mid-sized organization that deposits and analyzes business data (e.g., sales, customer, or operational records, ~10-100GB) for reporting, first in a Power BI Datamart and now in a Fabric warehouse:
  1. First things first – pack your belongings before moving:
  • Connect to your Fabric warehouse: Copy the warehouse’s SQL connection string from its settings, then connect to it in SQL Server Management Studio (SSMS).
  • Export tables to CSV: For each table, run a SELECT query and export the results as CSV files.
  • Stage your files: Upload these CSV files to a cloud storage service you prefer using Skyvia’s connectors.
  1. Reconnect Power BI – invite Power BI to the new home:
  • Use native connectors: Power BI has built-in connectors for most major warehouses.
  • Rebuild your semantic model: Recreate relationships and DAX measures.
  • Test everything: Make sure your reports still sing the same tune.
  1. Validate and optimize – unpack and make sure everything’s in its right place:
  • Compare record counts between old and new systems.
  • Test your reports thoroughly.
  • Add indexes for better performance.
  • Set up monitoring to catch any issues or problems.
In the end, Skyvia is more cost-effective than native connectors due to reduced labor costs. Its no-code pipelines and OData endpoints minimize setup and maintenance costs, addressing native connector drawbacks (e.g., DirectQuery performance, manual refreshes).
How to Choose the Right Storage Option for You: A Decision Framework
We have already covered many storage options, scenarios, and even took a side quest to drive around the Data Fabric Warehouse migration, and this is the last stage of this search. A few more questions and one comparison table stand between you and the best way to store data for Power BI.
  1. How much does your data weigh, and how spaghetti-like are the connections holding it together?
File-based storage (Excel or SharePoint) or on-premises databases (SQL Server) match smaller datasets with clear-cut relationships like a glove. However, any data tends to grow, and over time, you will need something mightier, such as cloud databases (like Azure SQL or Synapse) that can scale to deliver butter-smooth results every time.
  1. Do you need your data delivered via express overnight shipping, or are you fine with standard weekly/daily mail?
If your business suffocates without real-time insights, Power BI’s cloud databases or Data Fabric warehouses are your oxygen supply. They’ll keep your reports fresh and current. But if your reports don’t need real-time updates, file-based storage or on-premises databases with scheduled refreshes will do just fine.
  1. What are the cost implications of each solution?
Cost is always a factor. Sometimes, the main one. The only reason it’s in the middle of this guide is that we wanted to focus on other aspects, too. File-based storage and local databases are the wallet-conscious choice, perfectly suited for smaller operations or businesses with tight budgets. When you graduate to enterprise scale, cloud databases and Data Fabric warehouses come at a premium, but they offer scalability, performance, and adaptability that pay dividends on every investment.
  1. Do you have the expertise to manage a database or a cloud environment?
If your team isn’t full of database experts, file-based storage or on-premises databases are great for keeping things simple. As your appetite expands, cloud titans like Azure SQL, Synapse, or Data Fabric serve up gourmet features, but they come with a bit more technical know-how.
  1. Are your data demands expected to snowball in the coming years?
If you’re just starting or working with modest datasets, file-based storage or on-premises databases will do the trick, for now. But if you aim for fast growth, cloud storage like Azure SQL or Synapse, and Data Fabric warehouses are a better option, delivering adaptive scalability and premium features to support your analytical objectives.
And let’s summarize all these facts:
Storage OptionData Volume & Complexity Refresh Frequency Budget Scalability
File-Based Storage (Excel, CSV, SharePoint) Small datasets, simple relationships Daily/weekly Low cost Limited
On-Premises Databases (SQL Server) Medium to large datasets, complex queries Daily/Weekly Medium cost Moderate scalability
Cloud Databases (Azure SQL, Synapse) Large datasets, growing complexity Daily/Real-time Medium/high cost Highly scalable
Power BI Dataflows Medium datasets, standardized transformation Scheduled refresh (Daily/Weekly) Medium cost Moderate scalability
Power BI Data Fabric Warehouses Very large datasets, complex data models Real-time/Batch High cost Extremely scalable
The truth is, there’s no one-size-fits-all answer, but you’ve probably started to suspect this a few chapters before. Your best way to store data for Power BI depends on:
  • Data volumes
  • Real-time needs
  • Budget
  • Team expertise
But here’s the thing – you don’t have to figure it all out in one go. Begin with what makes sense for your current situation. Maybe that’s Excel files and the comfort zone of Import mode.
Eventually, you will grow, and numerous new needs will knock on your door. However, whenever you need to transfer data somewhere (with or without transformations), Skyvia will handle the plumbing so you can focus on what really matters – turning data into insights. From pulling CRM data into SharePoint files to orchestrating seamless migrations to modern cloud warehouses, it’s the toolkit for your data integration needs.
Try Skyvia today and discover how smooth data integration can be when you’ve got the right tool in your corner of the ring.
FAQ for Best storages for Power BI
Data published to the Power BI service is stored in your tenant’s home region. Artifact data goes to Azure Storage, and metadata goes to Azure SQL databases, both encrypted by default. To find the region, open the Help pane in Fabric or Power BI, select About and read the value next to ‘Your data is stored in’.
For a small team, Excel or CSV files on SharePoint or OneDrive with Import mode are the simplest way to store data for Power BI. They need no database skills. Files pile up, refreshes drag, and each report ends up with its own copy of the same cleaned table. At that point Azure SQL Database or another database earns its keep.
No. Power BI builds reports; it was never meant to be your system of record. Whatever an imported table shows comes from the last refresh, and incremental refresh deletes partitions as they age out of the archive window. Long-term records and history go in a database or data warehouse, and Power BI reads them from there.
An imported Power BI semantic model has a default size limit of 1 GB in the Power BI service. With the large semantic model storage format on a Fabric capacity, a model can grow up to the capacity size or a limit the admin sets. Uploads from Power BI Desktop are capped at 10 GB.
DirectQuery makes sense for a table too large to import, or for reports where people can’t wait for the next refresh to see a change. Because each visual queries the source database (through a gateway, where there is one), a slow server will mean slow reports. Import mode stays faster for most models that fit within the size limit.
Direct Lake is a Power BI storage mode in Microsoft Fabric that reads Delta tables from OneLake. Queries run on the VertiPaq engine, same as Import. The difference is the refresh: Direct Lake copies metadata only, so it fits big lakehouses and warehouses you couldn’t realistically import whole.
A Power BI refresh needs the on-premises data gateway when the service has to reach something inside your own network, say a SQL Server box in your data center. Your firewall stays shut to incoming traffic, because the gateway only makes outbound connections to Microsoft’s cloud. An Azure cloud database, by contrast, connects to the service without one.
