OData for Acuity Scheduling
Get a RESTful OData API server for your Acuity Scheduling data and make it available to clients in just a few minutes with Skyvia!
Expose Acuity Scheduling Data via OData
While Acuity Scheduling provides its own web API for data access, using a widely accepted OData standard for data access over the Internet is preferred in many cases. OData is supported in a number of data-related applications and technologies, and it makes consuming real-time Acuity Scheduling data or integrating them with other applications much easier.
Make your Acuity Scheduling data readily available in BI tools, web and mobile applications, integration interfaces, etc. via Acuity Scheduling OData endpoints. Get OData API layer with no coding, in just a few minutes!
If you need to provide access to your Acuity Scheduling data to your colleagues, clients, or other people, Skyvia Connect can offer several advantages.
Skyvia Connect provides bi-directional access to live Acuity Scheduling data in real time.
Create users and define passwords in the endpoint itself — no need to give your Acuity Scheduling credentials. Limit access by IP if needed.
Expose only the Acuity Scheduling tables and columns you need to share. Other tables and columns remain unavailable via the endpoint.
Create a connection to your Acuity Scheduling.
Share Acuity Scheduling data easily
