OData for Exact Online
Get a RESTful OData API server for your Exact Online data and make it available to clients in just a few minutes with Skyvia!
Expose Exact Online Data via OData
While Exact Online provides its own web API for data access, using a widely accepted OData standard for data access over the Internet is preferred in many cases. OData is supported in a number of data-related applications and technologies, and it makes consuming real-time Exact Online data or integrating them with other applications much easier.
Make your Exact Online data readily available in BI tools, web and mobile applications, integration interfaces, etc. via Exact Online OData endpoints. Get OData API layer with no coding, in just a few minutes!
If you need to provide access to your Exact Online data to your colleagues, clients, or other people, Skyvia Connect can offer several advantages.
Skyvia Connect provides bi-directional access to live Exact Online data in real time.
Create users and define passwords in the endpoint itself — no need to give your Exact Online credentials. Limit access by IP if needed.
Expose only the Exact Online tables and columns you need to share. Other tables and columns remain unavailable via the endpoint.
Create a connection to your Exact Online.
Share Exact Online data easily
