New
Skyvia MCP Server: Seamlessly link AI to 200+ data sources.
Explore now
OData for Pipeline CRM
Get a RESTful OData API server for your Pipeline CRM data and make it available to clients in just a few minutes with Skyvia!
Expose Pipeline CRM Data via OData
While Pipeline CRM provides its own web API for data access, using a widely accepted OData standard for data access over the Internet is preferred in many cases. OData is supported in a number of data-related applications and technologies, and it makes consuming real-time Pipeline CRM data or integrating them with other applications much easier.
Make your Pipeline CRM data readily available in BI tools, web and mobile applications, integration interfaces, etc. via Pipeline CRM OData endpoints. Get OData API layer with no coding, in just a few minutes!
If you need to provide access to your Pipeline CRM data to your colleagues, clients, or other people, Skyvia Connect can offer several advantages.
Skyvia Connect provides bi-directional access to live Pipeline CRM data in real time.
Create users and define passwords in the endpoint itself — no need to give your Pipeline CRM credentials. Limit access by IP if needed.
Expose only the Pipeline CRM tables and columns you need to share. Other tables and columns remain unavailable via the endpoint.
Create a connection to your Pipeline CRM.
Share Pipeline CRM data easily
