SQL Web API as a Service
SQL Gateway for remote access to cloud and database data
SQL Access to Any Data over the Web
Get API for SQL execution over the web with Skyvia Connect SQL endpoints. Connect over HTTP and retrieve the returned data in JSON format. No coding, no need to care about hosting and maintenance.
SQL endpoints allow using SQL against both cloud and database data and remotely connecting to on-premises databases with little to no configuration.
connect
model
publish
connect
Create a connection to the data you want to publish
model
Configure Security
Create user accounts/limit access by IP
publish
Publish
Set endpoint name and get ready-to-use endpoint URL
Supported Data Sources
Powerful SQL API
SQL endpoints provide easy-to-consume API that allow:
SQL Execution
SQL Command Execution
Execute SQL commands with parameters against the data source
Fetching Data
Fetching Data
Fetch returned data in pages in the JSON format
Querying Metadata
Querying Metadata
Obtain detailed information about data source objects and fields
Skyvia Connect Features:
SecurityAdditional Security Layer
Endpoint logsDetailed Logging
Supported connectorsConnectivity
Skyvia SQL API Clients
We provide ready-to-use clients for SQL API:
