OData for Freshsales Suite (formerly, Freshworks CRM)
Get a RESTful OData API server for your Freshsales Suite data and make it available to clients in just a few minutes with Skyvia!
Expose Freshsales Suite Data via OData
While Freshsales Suite provides its own web API for data access, using a widely accepted OData standard for data access over the Internet is preferred in many cases. OData is supported in a number of data-related applications and technologies, and it makes consuming real-time Freshsales Suite data or integrating them with other applications much easier.
Make your Freshsales Suite data readily available in BI tools, web and mobile applications, integration interfaces, etc. via Freshsales Suite OData endpoints. Get OData API layer with no coding, in just a few minutes!
If you need to provide access to your Freshsales Suite data to your colleagues, clients, or other people, Skyvia Connect can offer several advantages.
Skyvia Connect provides bi-directional access to live Freshsales Suite data in real time.
Create users and define passwords in the endpoint itself — no need to give your Freshsales Suite credentials. Limit access by IP if needed.
Expose only the Freshsales Suite tables and columns you need to share. Other tables and columns remain unavailable via the endpoint.
Create a connection to your Freshsales Suite.
Share Freshsales Suite data easily
