New
Skyvia MCP Server: Seamlessly link AI to 200+ data sources.
Explore now
OData for Recharge
Get a RESTful OData API server for your Recharge data and make it available to clients in just a few minutes with Skyvia!
Expose Recharge Data via OData
While Recharge provides its own web API for data access, using a widely accepted OData standard for data access over the Internet is preferred in many cases. OData is supported in a number of data-related applications and technologies, and it makes consuming real-time Recharge data or integrating them with other applications much easier.
Make your Recharge data readily available in BI tools, web and mobile applications, integration interfaces, etc. via Recharge OData endpoints. Get OData API layer with no coding, in just a few minutes!
If you need to provide access to your Recharge data to your colleagues, clients, or other people, Skyvia Connect can offer several advantages.
Skyvia Connect provides bi-directional access to live Recharge data in real time.
Create users and define passwords in the endpoint itself — no need to give your Recharge credentials. Limit access by IP if needed.
Expose only the Recharge tables and columns you need to share. Other tables and columns remain unavailable via the endpoint.
Create a connection to your Recharge.
Share Recharge data easily
