OData for Toggl Track
Get a RESTful OData API server for your Toggl Track data and make it available to clients in just a few minutes with Skyvia!
Expose Toggl Track Data via OData
While Toggl Track provides its own web API for data access, using a widely accepted OData standard for data access over the Internet is preferred in many cases. OData is supported in a number of data-related applications and technologies, and it makes consuming real-time Toggl Track data or integrating them with other applications much easier.
Make your Toggl Track data readily available in BI tools, web and mobile applications, integration interfaces, etc. via Toggl Track OData endpoints. Get OData API layer with no coding, in just a few minutes!
If you need to provide access to your Toggl Track data to your colleagues, clients, or other people, Skyvia Connect can offer several advantages.
Skyvia Connect provides bi-directional access to live Toggl Track data in real time.
Create users and define passwords in the endpoint itself — no need to give your Toggl Track credentials. Limit access by IP if needed.
Expose only the Toggl Track tables and columns you need to share. Other tables and columns remain unavailable via the endpoint.
Create a connection to your Toggl Track.
Share Toggl Track data easily
