OData for Zoho Projects
Get a RESTful OData API server for your Zoho Projects data and make it available to clients in just a few minutes with Skyvia!
Expose Zoho Projects Data via OData
While Zoho Projects provides its own web API for data access, using a widely accepted OData standard for data access over the Internet is preferred in many cases. OData is supported in a number of data-related applications and technologies, and it makes consuming real-time Zoho Projects data or integrating them with other applications much easier.
Make your Zoho Projects data readily available in BI tools, web and mobile applications, integration interfaces, etc. via Zoho Projects OData endpoints. Get OData API layer with no coding, in just a few minutes!
If you need to provide access to your Zoho Projects data to your colleagues, clients, or other people, Skyvia Connect can offer several advantages.
Skyvia Connect provides bi-directional access to live Zoho Projects data in real time.
Create users and define passwords in the endpoint itself — no need to give your Zoho Projects credentials. Limit access by IP if needed.
Expose only the Zoho Projects tables and columns you need to share. Other tables and columns remain unavailable via the endpoint.
Create a connection to your Zoho Projects.
Share Zoho Projects data easily
