Help Scout Looker Integration
Connect Help Scout data to Looker for reports, dashboards, and analytics.
Looker logo
Looker
Analyze Help Scout Data in Looker
Looker works best with data it can query quickly and in full—which is exactly what a data warehouse is built for. Skyvia loads your Help Scout data, including Customers, Users, Webhooks, etc., into the warehouse, and Looker connects to it natively. You get complete data, full history, no API limits, and refreshes as frequently as every few minutes.
    When all your Help Scout data lives in one data warehouse, every team works with the same numbers. No more conflicting exports, no more spending hours reconciling spreadsheets—just one trusted source for Looker reports.
    Combine Help Scout data with finance, marketing, product, and operational data to create Looker reports that span multiple systems.
    Automated syncs, error handling, and alerts keep your data flowing without manual work — your Looker dashboards stay current on their own.
What is Looker?
Looker is a data platform for data analysis, exploration, and insights for every business function.
Yes. Skyvia replicates your Help Scout data to a cloud data warehouse, which Looker then connects to. Skyvia supports Snowflake, Google BigQuery, Amazon Redshift, Azure Synapse, Databricks, and other data warehouses.
Turn Your Help Scout Data into Looker Insights in Minutes.
