Help Scout Pentaho Integration
Connect Help Scout data to Pentaho for reports, dashboards, and analytics.
Pentaho logo
Pentaho
Two Ways to Bring Help Scout Data into Pentaho
Replicate Help Scout data to a warehouse or get live access to it directly from Pentaho without data movement.
  • Replicate to a Data Warehouse
    Copy Help Scout data into a data warehouse, and use it as the foundation for deeper analysis in Pentaho.
    • Centralize all your data in one place
    • Keep a complete history of every record under your control
    • Combine with finance, marketing, and product data
    • No performance limits on report size
    See how replication works
  • Get Direct Access with Skyvia Connect
    Get real-time access to Help Scout data in Pentaho without copying it to a data warehouse.
    • Live access to Help Scout data
    • No data warehouse to provision or maintain
    • Quick setup
    • Lower costs for smaller workloads
    See how Skyvia Connect works
Data warehousing
Replicate Help Scout to a Data Warehouse
Skyvia loads your Help Scout data — including Customers, Users, Webhooks, etc. — into the data warehouse. Once your data is in, Pentaho connects to it natively, and starts working with a complete data, full history, and no API limits.
    When all your Help Scout data lives in one data warehouse, every team works with the same numbers. No more conflicting exports, no more spending hours reconciling spreadsheets—just one trusted source for Pentaho reports.
    Combine Help Scout data with finance, marketing, product, and operational data to create Pentaho reports that span multiple systems.
Live access
Connect Help Scout Data to Pentaho in Real-Time
Skyvia Connect makes Help Scout data available through a secure endpoint. Pentaho accesses it on demand, without any data movement.
Direct Data Access for Live Dashboards
  • Always-Fresh Data
    Access Help Scout data in Pentaho whenever you need it, without waiting for a scheduled replication run.
  • Reusable Endpoint
    Use the same endpoint with other compatible BI tools, AI assistants, spreadsheets, applications, and services.
  • No Warehouse Required
    Access Help Scout data without provisioning, configuring, or maintaining a separate data warehouse.
  • Quick Setup
    Configure a connection and endpoint instead of managing a replication pipeline, target schema, and update schedule.
  • Lower Cost for Smaller Workloads
    Avoid separate data warehouse storage and compute costs when direct access is sufficient for your reporting needs.
    Automated syncs, error handling, and alerts keep your data flowing without manual work — your Pentaho dashboards stay current on their own.
What is Pentaho?
Pentaho is a software for data integration, OLAP services, reporting, information dashboards, data mining and ETL.
Which approach should I choose - data warehouse or live connection?
Pick the data warehouse approach if you need historical data, want to combine multiple sources, or have large data volumes. Pick the live connection if you need real-time data, don't want to manage a warehouse, and your reporting scope is focused on Help Scout. You can also start with one and switch later.
No. Both methods are fully no-code. You set up everything through a visual interface — choose what to replicate or share, configure access, and you're done. No SQL or programming required.
Where does my data actually go?
For the data warehouse approach, Skyvia copies your Help Scout data into a warehouse that you own and control — Skyvia is the pipeline, not the storage. For Skyvia Connect (live connection), your data flows through Skyvia in real time and is never stored on our side.
Yes. Skyvia has a free plan that includes both Data Integration and Skyvia Connect, so you can test both approaches with your actual Help Scout data before committing to a paid plan.
What if my data volume grows over time?
Skyvia pricing scales with data volume, so you can start small and grow without re-platforming. You can change plans at any time, and there's no contract lock-in.
Does Skyvia support custom objects and fields?
Yes. Both replication and live connection support custom Help Scout objects and fields out of the box, alongside standard ones.
Turn Your Help Scout Data into Pentaho Insights in Minutes.
