Help Scout R Integration
Connect Help Scout data to R for reports, dashboards, and analytics.
R logo
R
Analyze Help Scout Data in R
R works best with data it can query quickly and in full—which is exactly what a data warehouse is built for. Skyvia loads your Help Scout data, including Customers, Users, Webhooks, etc., into the warehouse, and R connects to it natively. You get complete data, full history, no API limits, and refreshes as frequently as every few minutes.
    When all your Help Scout data lives in one data warehouse, every team works with the same numbers. No more conflicting exports, no more spending hours reconciling spreadsheets—just one trusted source for R reports.
    Combine Help Scout data with finance, marketing, product, and operational data to create R reports that span multiple systems.
    Automated syncs, error handling, and alerts keep your data flowing without manual work — your R dashboards stay current on their own.
What is R?
R is a programming language for statistical computing and graphics, developed by R Foundation for Statistical Computing.
Yes. Skyvia replicates your Help Scout data to a cloud data warehouse, which R then connects to. Skyvia supports Snowflake, Google BigQuery, Amazon Redshift, Azure Synapse, Databricks, and other data warehouses.
Turn Your Help Scout Data into R Insights in Minutes.
