Help Scout Shiny Integration
Connect Help Scout data to Shiny for reports, dashboards, and analytics.
Shiny logo
Shiny
Analyze Help Scout Data in Shiny
Shiny works best with data it can query quickly and in full—which is exactly what a data warehouse is built for. Skyvia loads your Help Scout data, including Customers, Users, Webhooks, etc., into the warehouse, and Shiny connects to it natively. You get complete data, full history, no API limits, and refreshes as frequently as every few minutes.
    When all your Help Scout data lives in one data warehouse, every team works with the same numbers. No more conflicting exports, no more spending hours reconciling spreadsheets—just one trusted source for Shiny reports.
    Combine Help Scout data with finance, marketing, product, and operational data to create Shiny reports that span multiple systems.
    Automated syncs, error handling, and alerts keep your data flowing without manual work — your Shiny dashboards stay current on their own.
What is Shiny?
Shiny is an R package for building interactive web apps straight from R.
Yes. Skyvia replicates your Help Scout data to a cloud data warehouse, which Shiny then connects to. Skyvia supports Snowflake, Google BigQuery, Amazon Redshift, Azure Synapse, Databricks, and other data warehouses.
Turn Your Help Scout Data into Shiny Insights in Minutes.
