OData Grow Integration
Connect OData data to Grow for reports, dashboards, and analytics.
OData logo
OData
Grow logo
Grow
Analyze OData Data in Grow
Grow works best with data it can query quickly and in full—which is exactly what a data warehouse is built for. Skyvia loads your OData data, including objects, into the warehouse, and Grow connects to it natively. You get complete data, full history, no API limits, and refreshes as frequently as every few minutes.
Use pre-built connectors to replicate your OData data to Amazon Redshift, Azure Synapse Analytics, Databricks, Google BigQuery, Snowflake, or another supported data warehouse.
    When all your OData data lives in one data warehouse, every team works with the same numbers. No more conflicting exports, no more spending hours reconciling spreadsheets—just one trusted source for Grow reports.
    Combine OData data with finance, marketing, product, and operational data to create Grow reports that span multiple systems.
    A clean, structured data warehouse is the foundation modern AI tools need. By centralizing your OData data, you also prepare it for the AI use cases you may run next—from natural language analytics to predictive models.
    Automated syncs, error handling, and alerts keep your data flowing without manual work — your Grow dashboards stay current on their own.
What is OData?
Skyvia OData connector allows connecting to any cloud app or database that provides OData interface.
What is Grow?
Grow is a BI solution for connecting and visualizing business data from various marketing, CRM, and financial data sources and sharing the reports.
Yes. Skyvia replicates your OData data to a cloud data warehouse, which Grow then connects to. Skyvia supports Snowflake, Google BigQuery, Amazon Redshift, Azure Synapse, Databricks, and other data warehouses.
You'll need to create one first. Modern data warehouses like Google BigQuery, Snowflake, and Amazon Redshift can be set up in minutes. Once your warehouse is ready, connect it to Skyvia and select the OData objects you want to replicate. Skyvia creates the target tables automatically, so you don't need to create them manually.
No. You can connect OData and your data warehouse, select the objects to replicate, and set a schedule through Skyvia's visual interface. No SQL or coding is required to configure the replication.
Yes. Skyvia offers a free Data Integration plan, so you can test replicating your OData data to a warehouse before moving to a paid plan.
Turn Your OData Data into Grow Insights in Minutes.
