Freshsales Suite (formerly, Freshworks CRM) and Oracle Integration
Skyvia is a no-code cloud data integration platform for connecting Freshsales Suite and Oracle data in a convenient and easy way.
Connect Freshsales Suite to Oracle in 3 Steps
Create connections to Freshsales Suite and Oracle from your Skyvia account. Sign up for free if don't have an account yet.
Skyvia offers both scenario-specific tools for integrating two data sources and visual designers for building complex data pipelines and automations involving multiple connectors.
Integration is configured in convenient wizards and designers, without coding. Depending on the product you choose, your integration can be trigger-based or run on schedule.
Skyvia allows you to view all the integration runs for any period, provides detailed per-record error logs in case of errors, and offers email notifications to help you be aware of the situation.
Orchestrating Data Pipelines
Think of Skyvia’s advanced tools as your data orchestra. Data Flow handles the instruments — transforms, joins, enrichments — while Control Flow conducts the sequence.
You can pull from multiple sources, sync them in real time, load them into various targets, and fine-tune behavior based on rules. Every data flow runs in harmony, and no task plays out of turn.
Load Data in Any Direction
Skyvia Import is a no-coding ETL solution that lets you extract your data from Freshsales Suite, transform them on the way, and load to the Oracle. It can be used for reverse ETL scenarios from Oracle to Freshsales Suite as well.
your ETL and reverse ETL scenarios with Skyvia Import in a convenient no-coding wizard — no hindrance, no hassle. Just results.
Get a Copy of Freshsales Suite in Oracle Easily
Want a live, queryable copy of your Freshsales Suite data in Oracle? Skyvia Replication makes that easy — great for backup, analytics, or feeding BI tools.
It builds tables automatically, keeps them up to date, and syncs only new or changed records. Whether you're running reports or troubleshooting production, your data mirror stays clean and current without constant babysitting.
Avoid Mismatches with True Bidirectional Sync
Even small mismatches in data can spiral into reporting issues, customer confusion, or compliance risks. Manual syncing can miss things. And when your data doesn’t match between systems, fixing it is frustrating and time-consuming.
Skyvia’s bidirectional sync automatically detects and applies changes in both Freshsales Suite and Oracle, keeping your data aligned and up to date.
Automate Routine Tasks and Sequences
A Freshsales Suite record appears. Your Automation steps in — checks for duplicates, enriches the record, and sends it to Oracle or other sources.
With Skyvia, these flows are visual and no-coding. Triggers include schedule-based, real-time, or manual starts. From there, each step performs a job: fetch data, filter, route, or transform. No scripts. Just logic that runs when needed, wherever it’s needed.
Integrate Freshsales Suite and Oracle data with minimal effort with Skyvia.
Skyvia offers data pipeline designer tools like Data Flow and Control Flow that allows including more than two data sources at once. In addition to Freshsales Suite and Oracle, Skyvia supports over 180 connectors.
