Front and Azure Synapse Analytics Integration
Skyvia offers you a convenient and easy way to integrate Front and Azure Synapse Analytics with no coding.
Replicate Front data to Azure Synapse Analytics
Front replication to Azure Synapse Analytics can be configured in under two minutes
Learn more about Replication
If you need to simply copy Front data to Azure Synapse Analytics without mapping configuration, you can use Skyvia replication. It allows you to create a copy of Front data in Azure Synapse Analytics and keep it up-to-date with little to no configuration efforts. You don’t even need to prepare the schema — Skyvia can automatically create tables for your cloud data.
All you need is to specify the connections to Front and Azure Synapse Analytics and select data to replicate, and Skyvia does the rest. It will copy the specified Front data to Azure Synapse Analytics and maintain this copy up-to-date automatically with incremental updates.
Use Connectors to Import Data Between Azure Synapse Analytics and Front
Skyvia offers a number of benefits for import Front data to Azure Synapse Analytics or vice versa. With Skyvia import you can perform any DML operations for imported Azure Synapse Analytics data in Front, import data from several Front objects at once, etc. These features are available for both directions.
Front logoAzure Synapse Analytics logo
Import Front to Azure Synapse Analytics
Import data without writing a line of code!
Azure Synapse Analytics logoFront logo
Import Azure Synapse Analytics to Front
Data import is simple for any direction!
How to integrate Front and Azure Synapse Analytics
Integration of Front and Azure Synapse Analytics with Skyvia is as easy as 1-2-3
Advanced Integration with Custom Mappings
Skyvia offers powerful visual editors which allow precise mapping configuration. It allows integrating data having different structure and offers the following mapping features.
Skyvia allows using complex mathematical and string operations and conditions for mapping data.
You can use lookup mapping to map target columns to values, gotten from other target objects depending on source data.
One-to-many
One-to-many
Skyvia allows you to map one Azure Synapse Analytics table to several Front ones.
When integrating data, you can fill some Front fields that don't have corresponding Azure Synapse Analytics fields (or vice versa) with constant values.
Integrate Front and Azure Synapse Analytics with minimal effort and in only a few clicks!
