Help Scout to SQL Azure
Copy (ELT) Help Scout data to SQL Azure in a few clicks and keep it up to date automatically.
Connect Help Scout to SQL Azure in 3 Steps
Create connections to Help Scout and SQL Azure from your Skyvia account. Sign up for free if don't have an account yet.
Skyvia's Replication is an easy-to-use ELT tool that lets you set up Help Scout replication to SQL Azure in several minutes. It allows you to copy Help Scout objects (including Customers, Users, Webhooks, etc.) to SQL Azure and keep the copy up to date.
You don’t need to prepare the SQL Azure database — Skyvia creates the tables, corresponding to the Help Scout objects, in the data warehouse automatically. Besides, it can automatically modify target SQL Azure tables according to new fields added in Help Scout.
Skyvia not just copies Help Scout data to SQL Azure once, it can keep your SQL Azure database up-to-date with Help Scout automatically, ensuring you always have fresh data for data analysis without any user intervention.
History mode allows you to store all versions of Help Scout records in your SQL Azure database instead of keeping only the current versions. You can select the mode for each object separately.
By default, target tables are named in the same way as source objects. Skyvia offers settings that allow you to change target table names — for all Help Scout objects in the integration or for each one separately. This is especially useful if you load several Help Scout instances into the same SQL Azure database, and want to use separate tables for them.
Skyvia combines a high-performance optimized batch data loading into SQL Azure with a granular, per-record data insertion and error logging in case of any errors.
If you need more than just to copy data from Help Scout to SQL Azure, you may use Skyvia's powerful ETL functionality for Help Scout and SQL Azure integration. Skyvia's Import tool will correctly extract Help Scout data, transform it, and load to SQL Azure when SQL Azure tables have different structure than Help Scout objects. Moreover, Skyvia Import allows loading data in any direction, supporting Reverse ETL scenario.
For more complex cases, you can use Data Flow and Control Flow tools. They are designer-based solutions for creating complex data pipelines, involving not only Help Scout and SQL Azure connectors, but any number of connectors in one integration. With these tools you can automate data workflows, involving custom logic, complex multistage transformations, combine data from different sources, load them into multiple destinations at once and many more.
Integrate Help Scout and SQL Azure data with minimal effort with Skyvia.
Skyvia offers data pipeline designer tools like Data Flow and Control Flow that allows including more than two data sources at once. In addition to Help Scout and SQL Azure, Skyvia supports over 180 connectors.
