Linear to Azure Synapse Analytics
Copy (ELT) Linear data to Azure Synapse Analytics in a few clicks and keep it up to date automatically.
Connect Linear to Azure Synapse Analytics in 3 Steps
Create connections to Linear and Azure Synapse Analytics from your Skyvia account. Sign up for free if don't have an account yet.
Many businesses want to benefit from the Azure Synapse Analytics ability to quickly perform complex analytical queries over petabytes of data, and need to load their data from Linear and other applications to the Azure Synapse Analytics service for centralized storing and data analysis. Skyvia's Replication is the perfect tool for secure replication to a data warehouse, as it loads data much faster than standard ETL tools and allows you to copy Linear objects (including Issues, Projects, Cycles, etc.) to Azure Synapse Analytics in just a few clicks and keep this copy up to date.
You don’t need to prepare the Azure Synapse Analytics database — Skyvia creates the tables, corresponding to the Linear objects, in the data warehouse automatically. Besides, it can automatically modify target Azure Synapse Analytics tables according to new fields added in Linear.
With Skyvia you can extract and load all the data from a Linear object or disable loading for some Linear object fields. You can also configure filters for data to replicate.
Skyvia not just copies Linear data to Azure Synapse Analytics once, it can keep your Azure Synapse Analytics database up-to-date with Linear automatically, ensuring you always have fresh data for data analysis without any user intervention.
History mode allows you to store all versions of Linear records in your Azure Synapse Analytics database instead of keeping only the current versions. You can select the mode for each object separately.
By default, target tables are named in the same way as source objects. Skyvia offers settings that allow you to change target table names — for all Linear objects in the integration or for each one separately. This is especially useful if you load several Linear instances into the same Azure Synapse Analytics database, and want to use separate tables for them.
Skyvia combines a high-performance optimized batch data loading into Azure Synapse Analytics with a granular, per-record data insertion and error logging in case of any errors.
If you need more than just to copy data from Linear to Azure Synapse Analytics, you may use Skyvia's powerful ETL functionality for Linear and Azure Synapse Analytics integration. Skyvia's Import tool will correctly extract Linear data, transform it, and load to Azure Synapse Analytics when Azure Synapse Analytics tables have different structure than Linear objects. Besides, if you ever need to load data back from Azure Synapse Analytics to Linear, Skyvia Import allows loading data in any direction, supporting Reverse ETL scenario.
For more complex cases, you can use Data Flow and Control Flow tools. They are designer-based solutions for creating complex data pipelines, involving not only Linear and Azure Synapse Analytics connectors, but any number of connectors in one integration. With these tools you can automate data workflows, involving custom logic, complex multistage transformations, combine data from different sources, load them into multiple destinations at once and many more.
Integrate Linear and Azure Synapse Analytics data with minimal effort with Skyvia.
Skyvia offers data pipeline designer tools like Data Flow and Control Flow that allows including more than two data sources at once. In addition to Linear and Azure Synapse Analytics, Skyvia supports over 180 connectors.
